Jag hade det ju lite bökigt med nerfarten till Lyseboten... Av en händelse såg jag en annan beskrivning på den nyss:
"The final road to Lysebotn consists of 22 hairpin turns in succession. It is easily the most dangerous road in Norway, and I can see why. Not only is it super steep, it is really narrow, allowing only one lane. You can’t see approaching traffic around the corners – and even if you do it wouldn’t matter as you can’t break on such a tight turn without straightening up and falling off the edge.
3/4 of the way down you will enter the scariest tunnel of your life. Water drips from the cracks in the rough, misshapen walls. The place is incredibly dark and the road slick with moisture. The very end of the tunnel is a well disguised hairpin turn. If you aren’t paying attention you might miss that completely and head straight into the wall – as a car did last year. The passengers were left seriously injured and had to be airlifted out."
En tjej från Litauen som beskriver sin resa ner... av någon anledning känner jag en sympati med hennes beskrivning
En (möjligen uppsnabbad) video från henne:
Skye's Fjelltur 2016
Re: Skye's Fjelltur 2016
Aaah
Finns ju båda vägräcke o asfalt
Tänk dig vägen grusat och utan räcke, då snakkar man äventyr
Nej fy s**** Ivar
Det hade nog inte gått i mera än Max 30 km/h då
@Joker. Jag undrar om det gick just mer än 30 det där. Hon behöll ju samma fart nere i Lysfjord när 30-skyltarna passerades.
Jag tror som Stefan; "en möjligen uppsnabbad video"
