Gas petcock position
Dumb question... as there wasn't an owners manual with this bike (1994) I'm not sure which is the "on" position or "reserve" with the gas flow ( arrow up or down)
Re: Gas petcock position
Wow, nobody knows which way is reserve?
Common some 600 owner! unfortunately my 650 lacks fuel petcock. I believe petcock means bränslekran in Swedish.
Rustygun, arrow up = fuel on. Arrow down = reserve. Arrow backwards = fuel off.
Ride on.
Ride on.
You da man !!! Thanks for the answer. ( lites a cigar and sips a little Scotch...its Friday)
No need to put it in "off" position though, the petcock only opens when the engine is running, by vacuum from the intake. Comes as a surprise to some.
(Drinks coffee-cuckoo, kaffegök, coffee and vodka, it's midnight sunday/monday)
And another tip, the coffee has to be hot, otherwise the gök won't mix properly.
Thanks, thats good to know! I had no idea it worked with carb vacuum.
( I'll try the drink, sound s good.
And then the bird calls out, "koo-koo", in the cuckoos coffee-nest.
I take a big mug of strong hot coffee with sugar and 6 cl Kronvodka.
"Själv blandar jag fredligt mitt kaffe med Kron till angenäm styrka och smak"
